JBL 1200.1
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53960
Printed Date: March 31, 2026 at 1:42 AM
Topic: JBL 1200.1
Posted By: evanc
Subject: JBL 1200.1
Date Posted: April 15, 2005 at 8:13 AM
I have owned two of these amps, in two different setups.  (The first one got stolen)  In case you do not own or are familiar with one (and in that case you may not be of much help anyways) they have a front and rear inputs which strikes me as odd for a mono sub amp. I understand they can balance out the fading, but I can't understand why you'd be running that much power without a front and rear amp as well.  I'll stop blabbering now...
I once heard from a buddy of mine that getting 2F-4M to use all the inputs would help the sound.  I went out and tried it, thinking if it did not I'd return the cables.  To my disbelief, it did work.  The bass woudl considerably louder than it was before at teh same volumes.  However, I was unable to tell if the sound quality got better or worse for I didn't have it for too much longer before it got stolen.
Has anyone else heard of doing this, and if so, are there any disadvantages to doing this (degredation of sound quality) or should this have been something I should have done from the get-go on my second chance with this amp?
Thanks guys..
Posted By: Francious70
Date Posted: April 15, 2005 at 9:40 AM
The 4 chanell inputs are more than likely for use for 5.1 audio. The bass that the discreet left/right front and left/right rear channels can't produce would be sent to the sub.
Paul
Posted By: evanc
Date Posted: April 15, 2005 at 11:20 AM
So, there is no disadvantage to usign the splitter?
Posted By: mikew04
Date Posted: April 15, 2005 at 11:54 AM
Did you reset the gains after you did this? You might be clipping and thats why it seems louder.
6th gen Celica | Alpine CDA-9827 | Pioneer GMX962 | CDT CL components | JBL 600.1 | Infinity Reference 12
Posted By: evanc
Date Posted: April 15, 2005 at 12:41 PM
Yes, I did reset the gains afterwards, but at the same gain level, the output was more, which is what confuses me.  I am just unsure if the amp performs better or worse with using both inputs opposed to using just one set.
Posted By: mikew04
Date Posted: April 15, 2005 at 3:45 PM
Thats interesting. Ive got the 600.1, i might just have to try that and see how it works out.
