what type of amp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54393
Printed Date: March 11, 2026 at 11:30 PM
Topic: what type of amp?
Posted By: kreate
Subject: what type of amp?
Date Posted: April 21, 2005 at 10:52 PM
I have a question I can't figure out what Kicker amp I can use with this sub...well actually there will be 2 subs and two amps running each sub.
Here is the specs on the sub..
Model S12X
Size 12"
Impedence, 1 or 2 ohm DVC
Max Rec Amplifier Power  (watts peak) 5000
Max Rec Amplifier Power (watts RMS) 2500
Sensitivity (dB 1W/1M) 87.7
Freq. Response 20-100 HZ
Mounting Depth (IN, CM) 8-9/16, 21.7
Mounting Cutout Square (IN., CM) 11-1/4,28.6
I would like to stick with Kicker for the amps also...So if anyone can help me out it would be great.
TIA
kre8
Posted By: pimpincavy
Date Posted: April 22, 2005 at 12:50 AM
I think Kicker makes a 2500.1, run one of those to each sub. The only question is, can your cars electrical system handle it?? You are going to need a huge alternator, and maybe even some extra batterys to power those bad boys.
Posted By: kreate
Date Posted: April 22, 2005 at 1:18 AM
Even if I have my alternator redone?  I know i'm gonna need a battery to run those mofo's...sh*t there gonna be in a Scion xB so I don't even think the battery nor the altenator is going to be able to handle it.
Posted By: Alpine Guy
Date Posted: April 22, 2005 at 11:47 AM
Start with an alternator then get a system to suit.  If you get 2 amps that big you are going to be popping alts and battery's weekly.  For that kind of system you are going to need about a 250 amp alternator to sorta keep up.
Check out www.mechman.com www.mean-green.com www.ohiogen.com Dominick Iraggi alts on e-bay.   You will not be able to get your factory alt rebuilt big enough to support the power needs you have.  If you cant get a bigger alt, throw your ideas out the window cuz it aint gona happen.
