taking off A-pillar trim with airbag
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54410
Printed Date: March 11, 2026 at 7:30 PM
Topic: taking off A-pillar trim with airbag
Posted By: docfnky
Subject: taking off A-pillar trim with airbag
Date Posted: April 22, 2005 at 6:11 AM
Hi all, i'm in the process of upgrading my sound system on the 05' RX330. There's a stock tweeter on the Apillar and i want to install some new one in the same location, but there's suppose to be some airbags behind the trim panel..is there any tricks into getting the trim off without setting the airbags off? thanks for the help
Posted By: NowYaKnow
Date Posted: April 22, 2005 at 6:20 AM
The airbags won't go off from just removing the trim. Just remove any bolts holding the pillar on (look for hidden access covers) and pull until it pops off. Some have bolts, others just clips depending on vehicle. Just don't use anything sharp that might puncture your airbag during removal, and if you change or add any wiring watch that it doesn't interfere with the airbag.
Mike
Posted By: geepherder
Date Posted: April 22, 2005 at 8:02 AM
If you have trim panels in the a-pillar that say "SRS" or "airbag", they usually pop off, and there's a screw behind them.
------------- My ex once told me I have a perfect face for radio.
Posted By: docfnky
Date Posted: April 22, 2005 at 7:12 PM
thanks a lot guys....mine does say SRS on it
