97 toyota 4runner head unit install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54458
Printed Date: March 11, 2026 at 9:36 AM
Topic: 97 toyota 4runner head unit install
Posted By: xoutlawz00x
Subject: 97 toyota 4runner head unit install
Date Posted: April 22, 2005 at 10:31 PM
im installing a head unit in a 97 toyota 4runner and now the dome light and the alarm don't work i don't know if i blew a fuse.. i was wondering if the stock head unit had to do with anything.. i cant find no info on it also the head unit is not hold the presets
please help
Posted By: overworked2
Date Posted: April 22, 2005 at 10:55 PM
you stuffed up posted_image It's alright, it happens to the best of us. LoL
Yes, you have most likely blown a fuse, my guess would be that the illumination wire on the back of the original is shorting out somewhere, does the instrument cluster still light up when you switch the headlights on? If not then it is the Ill. wire remove the head unit, cap off all exposed wires, there will be a couple  most likely. Whilst your there swap the power wires around, you have accidentally connected your Acc. feed to constant and your constant feed to Acc. So when you switch the car off, there is no constant power running to the memory bank of the head unit. Good Luck
Check all advice given with a meter
Posted By: kfr01
Date Posted: April 23, 2005 at 12:06 AM
Well, did you check the fuses? :-)
New Project: 2003 Pathfinder
Date Posted: April 23, 2005 at 4:13 AM
no not yet
