’04 Tundra preamp output?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54524
Printed Date: March 13, 2026 at 12:09 PM
Topic: ’04 Tundra preamp output?
Posted By: sevenpedaler
Subject: ’04 Tundra preamp output?
Date Posted: April 24, 2005 at 8:43 AM
Does anyone know if the stock Toyota head unit have any sort of preamp outputs?  I was going to upgrade the door speakers and add an amp but want to keep the stock head.  The head unit has cd/cass (no changer controls  or JBL)
If not, is there any speaker level/line level adapters worth buying to add an amp to this system??
I've been out of the loop for a while.  I used to compete over 10 years ago in IASCA and now just totally out of the loop as far as equipment etc.  I can still do a deck etc. but just not up with with the new gear.  Hell, I had the first stiffening cap in the midwest!
later................
srs
Posted By: mobileworks
Date Posted: April 24, 2005 at 11:17 AM
https://www.mobileworksaudio.com/shopexd.son?id=934
The PAC SNI35 is an adjustable Line Out Converter.  But to answer your question, No your tundra does not have RCA outputs.
Use something like the one posted. just make sure you get one that is adjustable.
