Sub wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54553
Printed Date: March 14, 2026 at 3:44 AM
Topic: Sub wiring
Posted By: ready247
Subject: Sub wiring
Date Posted: April 24, 2005 at 7:49 PM
I have a rockford fosgate p3001 mono amp if I hook up 2 4ohm svc subs to just the (a) output connected in parallel would that give me the 300 watts that the amp is rated a@ 2 ohms VS hooking 1 sub to each output (a) and (b) and getting 150 / 2 @ 4 ohms?
if im competly lost please tell me
Posted By: racer427
Date Posted: April 24, 2005 at 8:06 PM
If you hook up one sub to each output the amp itself will see a 2ohm load.
Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Posted By: stevdart
Date Posted: April 24, 2005 at 8:23 PM
^^ Right.  Using both sets of terminals on the amp is making a parallel connection, so two 4 ohm loads connected this way makes the amp perform into a 2 ohm load.  Otherwise, the way most commonly done is to connect the subs together in parallel first, then connect to the amp using only one set of terminals.  It's exactly the same either way.  It will be the rating of your amp at  __watts X 1 @ 2 ohms.
Posted By: ready247
Date Posted: April 24, 2005 at 11:15 PM
So no advantage either way?
Posted By: Ravendarat
Date Posted: April 24, 2005 at 11:28 PM
nope, may as well use both sets of terminals, generally looks cleaner
