5.25 and 6.5
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54558
Printed Date: March 14, 2026 at 6:27 AM
Topic: 5.25 and 6.5
Posted By: Walkercustoms
Subject: 5.25 and 6.5
Date Posted: April 24, 2005 at 9:32 PM
Will a 6.5 fit in a 5.25 factory hole? I don't not remember but, I thought they were like the same I know that sounds stupid because one is 5.25 and the other is 6.5 but I thought the 6.5 would fit the factory holes of a 5.25. Thanks
Posted By: auex
Date Posted: April 24, 2005 at 9:58 PM
What kind of car? If it is a civic then yes.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Ravendarat
Date Posted: April 24, 2005 at 10:33 PM
Generally the mounting holes are similar but the main issue usually comes in to play with the basket. Many decent 6 1/2's have baskets that wont fit into the factory hole with out some modification.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Date Posted: April 25, 2005 at 7:19 AM
Its a 04 Monte Carlo the fronts are 5.25 and my guy wants some Memphis and all they have are 5 or 5x7 no 5.25.
Posted By: auex
Date Posted: April 25, 2005 at 9:55 AM
Well generally 5.25=5.00. It should be difficult to build a baffle and install 6's in that car though.
Date Posted: April 25, 2005 at 12:03 PM
So, the 5 will fit is what you are saying?
Date Posted: April 25, 2005 at 12:31 PM
Id say its a 90% chance that they will fit fine and a 100% chance that if they dont it would be about 5 minutes of fabrication to make them fit perfect.
