Cd skips when subs hit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5461
Printed Date: April 18, 2026 at 2:50 AM
Topic: Cd skips when subs hit
Posted By: g_killion
Subject: Cd skips when subs hit
Date Posted: November 14, 2002 at 8:50 PM
This summer, I put two JL 8s in the trunk of my S90. They are firing forward so that you can (with the help of a blue neon light) see them and the amp through the ski hole. I have a cd changer in the trunk and a slot for one cd in the dash. The dash player works fine, no matter how hard the subs hit. When I move the same cd to the trunk, however, the cd skips whenever the subs hit hard. You guys have any suggestions?
Posted By: PLAYER69
Date Posted: November 14, 2002 at 8:52 PM
Move the CD player posted_image
Posted By: Velocity Motors
Date Posted: November 14, 2002 at 9:32 PM
What kind of CD player is it ? Id the mounting degree on the sides turned to the proper angle ? Check this out and post your results.
Posted By: DeathsJester12V
Date Posted: November 15, 2002 at 9:55 PM
yeah, do what Velocity said...sounds like the Mounting Degree settigns are off.......
If that isn't the cause repost..
Đễẳ†ђş 12\/ Ĵęśŧē®™
Posted By: JimF
Date Posted: November 16, 2002 at 4:33 AM
Had the same problem when I installed JL subs. You need a "soft" mounting kit which goes between the changer and the body of the car. Its very effective. Acts like the mountings at the base of buildings in earthquake zones (similar to JL subs, I think)!
JimF
Date Posted: November 17, 2002 at 9:53 AM
I don't know what the mounting degree settings should be.  I tried JimF's suggestion and it seemed to work.  I didn't buy a "soft" mounting kit because I didn't have time.  Instead, I put the foam that you insulate pipes with in between the body of the car and the changer.  I got them hitting really hard and no skips.  Thanks, guys
G_Killion
