Is It Possible to Blow 1 Coil in a DVC Woofer?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55025
Printed Date: May 14, 2026 at 8:56 PM
Topic: Is It Possible to Blow 1 Coil in a DVC Woofer?
Posted By: sydewayz_510
Subject: Is It Possible to Blow 1 Coil in a DVC Woofer?
Date Posted: May 03, 2005 at 3:16 AM
I have a 2 12 POWER DVC and both of them are wired the same way which is...parallel.....meaning i hooked the positive of one voice coil to the other positive of the other voice coil.....and the same for the negative side.....my subs are 4 ohms DVC.....i took my digital multi-meter and hooked it up to one of the subs...and it gives me a reading of 4ohms.....but when i tested the other speaker it gives me 2 ohms....my question is....can one of the voice coil on a singal sub blow out???...any response is greatly appreciated...thanks in advance...
Posted By: stevdart
Date Posted: May 03, 2005 at 7:44 AM
Read ohms resistance across each individual voice coil with the wiring removed.  Each set of terminals should read in the neighborhood of 3 ohms.
Second test:  connect one sub at a time wired parallel to the amp.  Listen for a difference in volume between the two.  If one sub hits softer and is less audible than the other one then it is very possible for a coil to be bad.
Posted By: KarTuneMan
Date Posted: May 03, 2005 at 10:52 AM
can one of the voice coils on a single sub blow out???...
YES !
Date Posted: May 03, 2005 at 10:53 AM
Theres the check......
Date Posted: May 04, 2005 at 12:54 AM
thanks guys for the response....and ("F word") man....one of my sub is bad....man i dont know how i could have blown that thing out.....each of my subs are 1000 rms and 2000 peak......man i thought with that must JUICE....the subs would give me a much better room for errors...but i guess not.....can someone please tell me how could this have happen.....and i wonder if my amp is OK.....please give me the proper procedures in checking my amp and its functionality...please....my amp matters more to me than my subs....thanks in advance...
Date Posted: May 05, 2005 at 1:32 AM
can someone please tell me the proper way to test an amp..
Posted By: haemphyst
Date Posted: May 05, 2005 at 6:14 AM
It's called a bench test, and best left to people with the PROPER (AKA expensive and heavy) equipment to do it correctly.
