2 gauge connectors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55056
Printed Date: May 15, 2026 at 6:50 AM
Topic: 2 gauge connectors
Posted By: derrickg
Subject: 2 gauge connectors
Date Posted: May 03, 2005 at 2:57 PM
i am having a big problem finding 2 gauge connectors in my area which sites can i go to to get some that can be trusted with my credit card
Posted By: Francious70
Date Posted: May 03, 2005 at 3:03 PM
1/0 gauge connectors will fit. If you can't find 2 gauge connectors, just use 1/0 gauge.
Paul
Posted By: racer427
Date Posted: May 03, 2005 at 4:41 PM
Here ya go, try these guy's. https://www.cardomain.com/shoptype/Wire+Terminals Chris ------------- Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Posted By: stevdart
Date Posted: May 03, 2005 at 5:43 PM
https://www.the12volt.com/installbay/forum_posts.asp?tid=53988&PN=2------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: haemphyst
Date Posted: May 03, 2005 at 8:00 PM
Personally, I have had better luck using a SMALLER connector than the wire gauge. It will fit more snugly to start with, and requires less smashing of the connector, or less solder, should you decide to go that way. Most connectors are really too big for the wire they SAY they are for. Since #4 connectors are pretty easy to locate, try one before you spend all of that cash on connectors for a #2 cable... I bet you'll be plesantly surprised...
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: racer427
Date Posted: May 03, 2005 at 8:51 PM
What type of connectors are you exactly looking for? Here are some 2g ring terminals. https://www.cardomain.com/item/ROCCPGSRT21P https://www.cardomain.com/item/ROCCPPSRT21P https://www.cardomain.com/item/LITBSRT2 https://www.cardomain.com/item/LITPRT2 https://www.cardomain.com/item/LITLSRT2 In any event, I have also used 1/0 guage terminals of 2g before. Chris ------------- Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
Posted By: supradude
Date Posted: May 03, 2005 at 9:34 PM
I second that haemphyst. I just recently had that same problem and I used 4 gauge connectors. I just opened them up a tad with a screwdriver, put the 2 gauge wire in, and crimped them with the vise. Then I soldered them. It made a very tight connection and was neat.
------------- '85 Toy
