Kicker 8" L7
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5627
Printed Date: May 10, 2026 at 7:34 PM
Topic: Kicker 8" L7
Posted By: sheriff
Subject: Kicker 8" L7
Date Posted: November 18, 2002 at 10:53 PM
I have a kicker 8"L7 which is 2 ohm.  I was wondering if it is better to have a two ohm or a 4 ohm L7.  I am going to hook the sub up to a 2 channel amp (MTX thunder 2300) around 600 watts.  Also, how would I hook the sub up to maximize the amps potential.
EPristia
Posted By: illmattix
Date Posted: November 19, 2002 at 3:22 PM
That's a Dual Voice Coil sub. In your situation its probably better to have the 4 ohm model but yours will work. That amp is not stable below a 2 ohm load so you will have to wire the speaker in series. That's from + to - to + to -.  If you wire it in parallel you will show your amp a resistance of 1 ohm and your amp will overheat.
Matt James
