2002 avalanche w/onstar, no sound
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56429
Printed Date: April 07, 2026 at 12:51 PM
Topic: 2002 avalanche w/onstar, no sound
Posted By: bballeric
Subject: 2002 avalanche w/onstar, no sound
Date Posted: May 25, 2005 at 5:44 PM
2002 avalanche with on star...thought and 1858 plug would work but i've got no sound...what else do i need???
Posted By: auex
Date Posted: May 25, 2005 at 6:01 PM
Doesn't that car have Bose???
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: May 25, 2005 at 6:02 PM
nope
Posted By: ss-installer
Date Posted: May 25, 2005 at 9:38 PM
i ran into the same problem with a 2001 yukon with onstar no bose. maybe an interface? it would play for a few minuted then quit.
Posted By: burns25
Date Posted: May 25, 2005 at 11:10 PM
You sure it doesn't have the amp behind the glove box high up in the kick panel?
Posted By: redpeppers
Date Posted: May 26, 2005 at 1:18 AM
if there is another harness in the back of the ractory radio then try to remote turn-on to the pink wire.....i have did this in the same car and it worked. I am not sure if a amp intergrator is needed but u can find that out when u get audio.
------------- Where theres is a wire there's a way.
Posted By: Asmodeus
Date Posted: May 26, 2005 at 2:45 PM
You will need a PAC OS1...This way you will still have On-Star operational and it will power the amp and hook up everything in one shot....No guess work or rigging involved.... ------------- Making the World A Louder Place
Posted By: kps67
Date Posted: May 27, 2005 at 11:18 PM
there are two harnesses that plug into the factory headunit. the main includes the speaker wires power ground and memory. then the second connector is the onstar plug. yuo have to power i think its the orange wire or a pink wire to cut the factory amp on or the speakers will only play for a few seconds then cut off.
Date Posted: May 28, 2005 at 5:14 PM
hey thanks for all your help and suggestions...just went ahead and bypassed everything and ran new wires to the speakers...guy said he didn't want the on-star to begin with...thanks though
