JBL 1200.1 or Brutus 1500D
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56635
Printed Date: March 28, 2026 at 2:33 AM
Topic: JBL 1200.1 or Brutus 1500D
Posted By: Sancho
Subject: JBL 1200.1 or Brutus 1500D
Date Posted: May 29, 2005 at 3:11 PM
which one would you prefer more to run one kicker solo baric 12L5 at 1ohm?
thank you
Head Unit:Alpine CDA 9835
6.5 MB Quart Pce 210
Amp:JBL 80.4
Amp:JBL 1200.1
Sub:Adire Brahma 12 MKII
Posted By: stevdart
Date Posted: May 30, 2005 at 2:04 AM
You want the output at 2 ohms, not 1 ohm.  Use the DVC 4 ohm sub, coils parallel-wired to 2 ohms.  Maximum acceptable power to the sub is 600 watts and either of those amps will grossly overpower the sub at 1 ohm power output.  See if one of those amps will output no more than 600 watts into a 2 ohm load.
