Power Acoustik LT1920 Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56650
Printed Date: March 27, 2026 at 8:02 PM
Topic: Power Acoustik LT1920 Wiring
Posted By: ut_baseball_30
Subject: Power Acoustik LT1920 Wiring
Date Posted: May 29, 2005 at 10:33 PM
I have a Power Acoustik LT1920 two channel amp. It's 2-ohm stereo/4-ohm mono stable, RMS Power @ 4 Ohms: 370W x 2. I've also got 2 Audiobahn 10 inch Flame Excursion subwoofers. They are both 4 ohm. I need help on how to wire all this together. If you have any suggestions please help.
posted_image
Posted By: stevdart
Date Posted: May 30, 2005 at 1:36 AM
You can either just connect one 4 ohm sub to each of the channels, or if the subs share a box they can be wired together like this:
posted_image
........and bridged to the amp.  Same amplifier ouput either way.  With two SVC 4 ohm subs you cannot make that amplifier work at its maximum 2 ohm stereo capacity.  Look at the RMS rating of the subs...at the Audiobahn-measured 450 RMS each they are a good matchup with that amp with either of the above connection methods.  You should actually give those subs about 350 watts each, which that Power Acoustik amp claims to do.
Date Posted: May 30, 2005 at 11:36 AM
So, would this be installed in a parallel or series format?
posted_image
Posted By: samroza
Date Posted: May 30, 2005 at 12:01 PM
The above image is in series.
Sam Roza
Date Posted: May 30, 2005 at 12:46 PM
And I will get the most power out of my amp this way, right?
posted_image
Posted By: samroza
Date Posted: May 30, 2005 at 12:50 PM
Steve is suggesting that you follow the picture's wiring, and put the amp into mono-bridged output. Whether or not you will get the 'most' from your setup in this fashion, I honestly don't know, but mono-bridging is generally regarded as the best way to extract the most power from an amplifier.
Sam Roza
Posted By: stevdart
Date Posted: May 30, 2005 at 1:19 PM
Samroza's right.  The amp might be able to make more power than this, but not into two 4 ohm subs.  But like I said above, match up power output to sub rating.  You'll be correct with this matchup.
Date Posted: May 30, 2005 at 10:58 PM
Thanks alot guys, you've been a big help
posted_image
