Amp powers up but theres no sound
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56657
Printed Date: March 27, 2026 at 3:28 PM
Topic: Amp powers up but theres no sound
Posted By: Kapedogg
Subject: Amp powers up but theres no sound
Date Posted: May 30, 2005 at 12:04 AM
Just bought a brand new MTX MXA4002 off of ebay, got it hooked up, but the sub doesn't fire up. The amps red light is on, which I assume is the power light, but nothing happens. I tried it on another speaker, and nothing there either. I hooked up a different amp and the sub fired up fine, so I know it has to do with the amp. Both the fuses are fine, All the fuses in the system are fine. I tried other sets of RCA's, which all got sound to a different amp, but that didn't work either. I am completely stumped here, any suggestions???
Posted By: rabenoja
Date Posted: May 30, 2005 at 12:37 AM
Well from the sound of it, it looks like you covered all the bases. You checked the subs with another amp and they work fine, so it's not the subs. You've checked power, ground, remote and rca's when you swapped the other amp so, it's not that. I'd check the gain on the amp and if it's properly set then, it looks like you got a messed up amp.
Posted By: Kapedogg
Date Posted: May 30, 2005 at 1:47 AM
That's what I was thinking too. I've moved the gain down and up, and no response. So, I'm guessing my amp is messed up. What's weird is that it came with a sheet showing its power output. Is there something I might have done to cause this? I've installed quite a few systems over the years, and this amp was replacing an old one, so I don't think I did anything wrong...
Posted By: kgerry
Date Posted: May 30, 2005 at 5:02 PM
grab a meter and actually meter the power and remote connections at the terminal connector......do you have power right at the input of the amp?
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
