99 Chevy S 10 Single cab sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56770
Printed Date: March 26, 2026 at 4:16 AM
Topic: 99 Chevy S 10 Single cab sub
Posted By: Sweekster
Subject: 99 Chevy S 10 Single cab sub
Date Posted: May 31, 2005 at 9:32 PM
Greetings all,
I've searching the web (and this forum) and have not found the answer I'm looking for. So here goes...Is it possible to install a 12 in sub in a regular cab s10? I've seen everything for putting in a single 10 inch but no 12. The truck has a full bench seat and the amp is installed over on the driverside of the rear wall. My customer wants to keep the jackbox and put the sub (an older MTX 4124A) in the middle. If it's possible, i'd like some dimensions and/or box recommendations.
Thanks guys
Duane...
If you think you're confused, imagine how you feel.   :errr:
Posted By: soundmasta
Date Posted: June 01, 2005 at 7:39 AM
i did this box for a single cab s 10 at my shop, it's a 10" but there would be room for a 12 if thats what the guy would've bought.
https://i2.photobucket.com/albums/y28/jeremykowatch/Picture3015.jpg
https://i2.photobucket.com/albums/y28/jeremykowatch/Picture3012.jpg
Date Posted: June 01, 2005 at 8:15 AM
That's exactly what I'm looking for. Only difference is I just need the speaker to be where the amp is in your pic. Would you happen to have the specs on that box?
Duane...
If you think you're confused, imagine how you feel.   posted_image
Date Posted: June 02, 2005 at 7:27 AM
well...we never build the same box twice here, pretty much everything is custom work, even the little jobs like that one. next time he comes in i will get measurements on it though. i guess i would just suggest to build it small enough to fit.
