JL Audio Problem RBC-1 with 500/1
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56987
Printed Date: May 05, 2026 at 11:20 PM
Topic: JL Audio Problem RBC-1 with 500/1
Posted By: mbkowns
Subject: JL Audio Problem RBC-1 with 500/1
Date Posted: June 03, 2005 at 4:20 PM
I have a JL AUDIO 500/1 mono amp and it has worked great since I got it now I am tring to hook up the RBC-1 (volume knob) and its not working.  I havn't changed anything on the amp and I followed the directions it came with to the letter but I can't figure out why it won't control the volume...
Can someone help me out ?
Posted By: Blowntweeters
Date Posted: June 03, 2005 at 6:25 PM
thats strange is there a JL dealer in your area ?"  if there is i would go there thats a tough one not looking at everything
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Posted By: mbkowns
Date Posted: June 04, 2005 at 2:41 AM
I had the same sub in my 95 civic which I sold and it didn't work there i figured something must of been up so I decided to forget it since I had my 2005 Mustang GT on order.. Now that I have my stang and the amp installed its still not doing its thing.
Do I have to turn off anything on the amp?
posted_image
Do I need to turn off BASS EQ ? is there any special setup I need to be doing here ?
thanks
-KYLE
Posted By: shiftmx11
Date Posted: June 04, 2005 at 3:43 AM
its might be your cable or connecters ends, maybe try a 6 pin telephone cable and make sure your pins line up right and are not bent
Posted By: tcss
Date Posted: June 04, 2005 at 12:55 PM
The RBC-1 is not a "volume" or gain control. It is a single band EQ fixed at 60hz.
Posted By: mbkowns
Date Posted: June 04, 2005 at 2:08 PM
so it ajusts only that I thought it would control the volume... Well how do I get it so I can control the volume?  RCA volume controller?
I just need to have the ability to controll the volume of the sub
Posted By: tcss
Date Posted: June 04, 2005 at 3:04 PM
That should work fine.
Posted By: mbkowns
Date Posted: June 04, 2005 at 5:24 PM
what should
Posted By: geepherder
Date Posted: June 04, 2005 at 9:01 PM
Yes, you can use a knob on the sub RCA's.
Posted By: mbkowns
Date Posted: June 05, 2005 at 4:30 AM
any good ones you know off?
