1992 GMC Sierra, CD wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57483
Printed Date: May 05, 2026 at 2:57 PM
Topic: 1992 GMC Sierra, CD wiring
Posted By: Hotrodhoose
Subject: 1992 GMC Sierra, CD wiring
Date Posted: June 11, 2005 at 1:42 PM
I have a 1992 GMC Sierra Pick Up Truck, full size.  I am putting in a CD player made by sony.  My truck only had a radio before, no tape or cd player.  There are only 6 wires to the back of the radio: Black, White, Gray, Red, Orange, and Yellow.  I cant seem to get anything to work.  The CD player will sometimes come on, but no sound, and it says failure for the radio, which i am thinking i dont have the antannea wired up right.  The speakers do not put out any sound either.  And the Head unit only works sometimes, not all the times.  Please Help Me!!!
Thanks Mike
Posted By: Autoobsession
Date Posted: June 11, 2005 at 2:23 PM
U had to get that special kit for the dash right? If so the radio wiring wasnt actually goin to the radio. The tuner is to the lower left of the where the radio was and u have to wire the radio to there.
Date Posted: June 11, 2005 at 2:46 PM
The original radio is still in the truck,  i cut the wires that were leading to it.  To wire up the head unit i bought.  I did buy that kit that you have to take out the center of the dash where the hole is for like loose change and stuff, my original radio sat above the a/c and heater controls in the gauge cluster dash thing.  I just need to know what colors lead to what in a 6 wire radio like i have, and what i should wire them to in the head unit.
Thanks Mike
Posted By: hawn13
Date Posted: June 11, 2005 at 4:29 PM
like autoobession said the wires you need are at the tuner pack which is right above your gas pedal. just get  a 70-1858 metra harness and it will plug right into the factory harness and you just need to hook up your aftermarket harness to 1858 and your done. also your ant is also plugged in on that tuner pack. you will also need an ant. adapter.
Posted By: samroza
Date Posted: June 12, 2005 at 8:14 AM
Like they said-wire the stock connector back in, since you've hacked it, and get the metra plug. All you will have to do then is wire the metra plug to your radio and plug the metra harness into your stock connector.
Sam Roza
Date Posted: June 12, 2005 at 10:34 AM
Ok, i have the connector but i dont know where it goes?  I dont see anything like the plug thats on this connector.  One of you said it was above my gas pedal but all i can find above my gas pedal is some flat connectors, the connector i have is like a two row.  One on top of the other, where does it go?  Thanks, Mike
Posted By: samroza
Date Posted: June 12, 2005 at 12:29 PM
Hotrod-
Do you have the Metra harness for your particular year/model of Chevy? If not, go and get it. Using the stock plug that came out fo the back of your truck's original radio, all you will have to do is wire your new head unit to this plug, and plug it into the stock wiring-no messing with the tuner module or anything else.
Metra plugs are usually available for sale at Circuit City, GoodGuys, Walmart, or any other place the deals in or installs aftermarket sound stuff.
Sam Roza
Posted By: auex
Date Posted: June 12, 2005 at 12:35 PM
It is a big silver box with fins. There are 3 7mm/ 9/32 bolts holding it into the car. Remove them, unplug the harness from the box, throw box in garbage, then plug your aftermarket harness in and you are done.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
