Wiring a Tbird
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57508
Printed Date: May 06, 2026 at 1:59 AM
Topic: Wiring a Tbird
Posted By: ivant2
Subject: Wiring a Tbird
Date Posted: June 11, 2005 at 10:19 PM
Been having a dispute with a friend over the proper way to install multiple batteries in a car. At this present time i have 4 red top Optima batteries running in the trunk of a 96 ford thunderbird. Im using a 1000x US Amps, along with 2 tube 600 watt amps also made by US Amps. Im using in total 5 red top optima batteries and i have a breaker (rated 150 amps each) before each battery. They are all crosslinked together in the rear through the breakers. My issue is which side of the breaker do you place the powerlines feeding the amps and which side to go to the batteries. Also would you install one amps power wires in line with one battery or would it not matter?
Just for fyi i have a sr200 stinger isolator and 2 (1) farat capacitors wired in as well.
Would appreciate help in solving this issue/ would take advice on another way of wiring this.
~Mike
Posted By: stevdart
Date Posted: June 12, 2005 at 12:36 PM
Just use the standard guidelines for fusing wiring:  the fuse (or in this case circuit breaker) is immediately after the source.  And every power wire must be fused.  With what you have, I would look at the four batteries in the trunk as a "battery block" and deal with them as if they were a single battery.  So instead of a single battery you have four individual batteries connected in parallel, and the wiring connecting one to the other is protected by a circuit breaker close to the source, which is the battery on the upstream side.  The breaker will trip, or a fuse will blow, whether the excess current comes from the source side or the downstream side.
This block of batteries would fall in line after the isolator and before the caps (which you might also look at as a "capacitor block".  You can buy connectors for multiple caps that allow for fusing of the power wire between them, or just put in a fuse or breaker at that point, too, as well as after the second cap.  After the caps would come a fused distibution block, from which you will send (fused) wires to the amplifiers.  You will have to purchase the proper distro block and any additional fuses, fuse holders or circuit breakers that are needed.
Isolator > wire w/ breaker near source (isolator) > 1st battery pos term > wire w/ breaker near source (1st bat in trunk) > 2nd batt pos > wire w/ breaker near source > 3rd batt pos > wire w/ breaker near source > 4th batt pos > wire w/ breaker near source > cap 1 > wire w/ fuse near source > cap 2 > wire w/ fuse near source > fused distro block > amps.
The fusing in the distro block will protect the wiring to the amps, and the amps themselves will be protected with their own fuses.  The "source" is the power supply from which a wire goes to another component and there is a new "source" with the addition of each component in the chain which begins at the alternator.  Fusing is done near the source, and either breakers or fuses can be used to protect the wiring between power components.  Grounding of the caps and each battery, as well as the amps, is to chassis.  You can use a grounding (unfused) distro block to help make it more manageable.
And just as with the use of multiple batteries in any appliance, the 4 batteries in the trunk should be of identical age and use.  But unlike the batteries in a flashlight, where series connecting adds the individual voltages together to form a sum...your batteries are connected in parallel (pos to pos) so that 12 volts will be maintained and amperage capacity will be summed.
