Car system problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57538
Printed Date: May 06, 2026 at 6:44 AM
Topic: Car system problems
Posted By: Hondacivicexboy
Subject: Car system problems
Date Posted: June 12, 2005 at 12:45 PM
I just got my first car.Its a 1998 Honda Civic Ex and the first thing im doing to its is putting a system in it.My dad gave me his Subs enclosed in the box.There two 12" baja's and I have a late model 500wat Bazooka amp and  new 600 wat pioneer amp and two 6 and a half inch polkaudio speakers in it right now.It's not kicking like I wanted it too.But it does sound good.I was wondering what I should get to make it have more bass.I was think bigger speakers?Like 15" or 18 " JL Audio.Not sure if 18's will fit in my trunk, is there a way to fit them if I decide to get them?Also how can I fix that rattling in my trunk?Should i use like a expanding foam? Thanks, David
Posted By: dwarren
Date Posted: June 12, 2005 at 1:40 PM
You have a number of questions to adress here. But as far as bass goes, you are correct in that larger diameter drivers generally produce more volume, however properly matched 10"(s) or 12"(s) can be very loud. This can be acheived by using the proper enclosure (very crucial) and applying the proper power to them.
You don't necessarily need huge amounts of power to have loud bass. My guess is those subs aren't very good and probably need to be upgraded.
There are many ways to stop rattling, I suggest you do a search on this site for more info as there are many many threads that deal with issue.
Posted By: Blowntweeters
Date Posted: June 12, 2005 at 4:32 PM
dwarren is right i  got 148.1 SPL out of 2 12" subs it was because of the enclosure how much do you want to spend oh the subs and amp you could also go with a single 15" sub
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
