Weird stereo issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57606
Printed Date: May 07, 2026 at 3:40 AM
Topic: Weird stereo issue
Posted By: MustangJim
Subject: Weird stereo issue
Date Posted: June 13, 2005 at 11:04 AM
I have a 2001 Mustang Gt with a Sony cdx-f5700 head unit going into a JL 300/4 amp. In the front I have 6.5 Infinity seperates and in the rear deck I have Pioneer 6 x 8's. Every once in a while the rear passenger side 6 x 8 gets fuzzy. All other speakers sound fine. I have tried new rca cables,new speaker wire,and a new speaker. The head unit is not that old. I assume it is the head unit,but is there anything I might be missing? I also have a JL 500/1 amp going into two 10 Jl's. Sometimes the speaker is ok,but othere times as soon as I turn on the stereo,it is fuzzy. Please help.
Jim
Posted By: us_test
Date Posted: June 13, 2005 at 11:20 AM
Not familiar with your HU but if it has 2 rca outs try to swap front to back (this will determine if it is the HU.) channels. Have you tried to use the know good chanells from amp (the front) to power the back speakers? Are you running any power cables next to RCA.
Date Posted: June 13, 2005 at 12:16 PM
I'm more confused now. Stereo sounded fine,then there was a little pop,and speaker became fuzzy. Switched rca's at the head unit,and same speaker remained fuzzy. Switched rca's at the amp,and the same speaker was fuzzy. Yesterday I temporarily hooked up different rca's and different speaker wire from the amp,and it was still fuzzy. I then hooked up a different speaker,and it was still fuzzy. Now the only other weird thing is this....I had diferent amp in there before the JL. Initially,I had the speaker wires mixed up on the amp. Had first amp in,and same speaker is fuzzy,awitched amp,and screwed up wiring,and front left speaker was fuzzy,switched amp wiring back,and same rear right speaker is fuzzy. It has to be in the wiring,but what am I missing?
Posted By: us_test
Date Posted: June 13, 2005 at 12:59 PM
OK - Check to make sure the speaker wires do not have strands touching the terminals (like the + speaker wire having a strand touching the - terminal on the amp). Check to make sure the speaker basket and connectors is not coming in contact with the metal on the car. I assume when you did this test you used the same channel on the amp if not use only one channell at a time to test speakers, if 1 channel works fine for all 4 speakers, go to the next channel (LABEL the wires, like so FL (front left) FR (front right), also lable the + and - on the wires.
