Richmat quality?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57698
Printed Date: April 03, 2026 at 6:11 PM
Topic: Richmat quality?
Posted By: jonchos
Subject: Richmat quality?
Date Posted: June 14, 2005 at 7:48 PM
has anyone heard of richmat? I want to do my trunk and I was wondering wich is the cheapest I can get that would do the job right. dynamat is expensive. Any suggestions?
Posted By: haemphyst
Date Posted: June 15, 2005 at 3:10 PM
Weel, it is CLAIMED to be as good as Dynamat... Anybody can claim anything they want... Is it as good? It seems as though they offer a warranty on performance, so give it a shot!
Posted By: us_test
Date Posted: June 15, 2005 at 3:43 PM
A bit of subject but I just got some undercoating spray (it says it is used to sound deaden as well) $2.68 per spray can from WalMart (can is bigger than Dynamat and weighs more by hand feel).  The Dynamat spray is $25 at Tweeter (online may 10+ 5 to ship).  I'm thinking this product from WalMart has to be close to 90% or more as effective as the Dynamat or smilar product but without the price markup.  I'm doing to door panles tonite (1 can for each) and if it works well I'll keep using it.
(1) Kenwood Excelon Head Unit KDC-X589 (24 bit Burr Brown DAC, 3 X 4 volt RCA).
(1) RF Punch 250A2 - running the components.
(1) Hifonics 6.5" Atlas Components (18db crossovers).
Posted By: jonchos
Date Posted: June 15, 2005 at 5:13 PM
Please let me know how it works. I would go and buy some can right away if it works for you. Let me know how thick it is when applied. Thank you
Posted By: us_test
Date Posted: June 16, 2005 at 7:32 AM
It is thick.  One coat is 75% the thickness of a regular folded paper knapkin.  At first I did not shake the can so it was coming out like paint (then I read the DIRECTIONS) and shook the can for 1 minute.  It came out textured and thick.  1 can can do 4+ coats on a door panel.  It dries pretty well in about 45 minutes.  I can definetley tell you it works.  I was driving today and normally cars pass you by and you can hear them (faintly), now they pass by and nothing is heard, this is also in 98 camry which is kind of quiet to begin with anyways.  Get this, you won't be dissapointed.  I'm getting more for the trunk.  WalMart $2.68 a can.
Posted By: us_test
Date Posted: June 16, 2005 at 9:00 AM
Wanted to add that the total thickness with 4 coats was the same as 3 or 4 double folded paper knapkins.
Posted By: nguyenk
What is the name of the product?
Posted By: stevdart
Date Posted: June 16, 2005 at 10:35 PM
McMaster-Carr has an asphalt-based sound damper sheet, 36 sq. ft. for about $42.  If you're interested I'll post how to find it, as it is a PITA on my part.  Oh, here we go, a search through the forum was the easiest way:  https://www.the12volt.com/installbay/forum_posts.asp?tid=33610&KW=McMaster%2DCarr
Posted By: customcarchris
Date Posted: June 17, 2005 at 12:51 AM
So I have a question for anyone who has used these products...
Is is better to just use the spray stuff for everything like the trunk or does the sheeting like Dynamat and B-Quiet work better for the trunk and flat spaces.
I would think the undercoating would be easier to apply, but does it make a mess where you don't want to touch it?
I am at the point that I really want to start doing this sound deadening thing in my trunk before I put my finished boxes in, and I would like to have the easiest, but still the best prduct.
P.S. ~ I would rather sacrifice ease for a better working product anyday, but a little of both worlds would be nice.
Anyone have any opinions on the subject?
Posted By: oonikfraleyoo
Date Posted: June 17, 2005 at 1:19 PM
I just got some of this
It works really good and is easy to work with. It doesn't smell bad either. And I only paid like $118 for 100sq.ft. shipped. Thats 2 rolls, each 18" x 33'. Enough to do 3 coats in most spots.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: stevdart
Date Posted: June 17, 2005 at 7:12 PM
The post I made above is actually on page 3274.  It's .07" thick, or 70 mils.  Good stuff.
