HU cycling power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57760
Printed Date: April 02, 2026 at 2:14 AM
Topic: HU cycling power
Posted By: teklife256
Subject: HU cycling power
Date Posted: June 15, 2005 at 5:37 PM
I am installing a Pioneer DEH-1500 which has given me a couple of issues. I was able to resolve the first issue in which I was seeking a value for the 12V constant inline fuse which was not provided with the wiring harness. I tried a 5A which seemed to work out.
After listening to the stereo for about a half hour the second issue developed. Now, my second issue involves the power being cycled on/off about every 2 seconds. The HU will power up, screech and power down and repeat. Upon, disconnecting the speakers the screech still occurs from within the HU. HELP!!!!! I have tried to find a better ground which does not seem to help the situation. Should I disconnect everything minus the 12V constant and switched power? Or what kind of troubleshooting is possible?
Posted By: dwarren
Date Posted: June 15, 2005 at 5:41 PM
Sounds like a defective unit if the noise is actually coming from the unit.
