Double stereo, single set of speakers...
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58713
Printed Date: March 23, 2026 at 11:03 PM
Topic: Double stereo, single set of speakers...
Posted By: maglin
Subject: Double stereo, single set of speakers...
Date Posted: July 02, 2005 at 2:02 AM
ok, i wanna build up a computer based kit to store my music, play it through MP3 so forth and so on, and meanwhile, and a HU. anyways, would i be able to do this with only 1 set of speakers? currently, i'm running 4 speakers *2 front, 2 rear* straight from a HU... i wanna put in 2 amps, forward and back, powered by a USB SoundBlaster card *takes digital sound from computer and outputs on the standard LR cable used between most HU and amps* and run wires from the amps to these speakers... however, i'm worried that it'll feed back up into the HU effectively destroying it. needless to say, i can't experiment with it, wondering if people had ideas.
~~Dan
Posted By: ravenndude
Date Posted: July 02, 2005 at 2:31 AM
if your HU has any kind of input you can take the out from the PC and put it to the HU and control volume from there also.
Also check www.mp3car.com if you haven't already
