Wiring MTX4250 Amp toUL-D612, Sub 6 ohm DVC
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=58838
Printed Date: April 22, 2026 at 7:54 AM
Topic: Wiring MTX4250 Amp toUL-D612, Sub 6 ohm DVC
Posted By: Welsh
Subject: Wiring MTX4250 Amp toUL-D612, Sub 6 ohm DVC
Date Posted: July 04, 2005 at 9:34 PM
Trying to connect,
MTX 4250D Thunder Mono Amp.
Key Features
Amplifier Type      Mono Channel
Bass Boost      With Bass Boost
Bridgable      Not Bridgable
Power Output
RMS Power at 2 Ohms      250 W x 1
RMS Power at 4 Ohms      125 W x 1
Performance
Frequency Response      20 Hz - 200 Hz
Low - Pass Frequency      40 Hz - 200 Hz
Signal to Noise Ratio      100 dB
Bass Boost Frequency      40 Hz
THD at Rated RMS Power      1 %
Other Features
Input Voltage      12.5 volt
MOSFET amp      Yes
3 Way Ready      No
And
ULTRA LINEAR ULD612 12” SUBWOOFER
    * 450W RMS
    * 900W Max
    * Dual 6 Ohm Voice Coil
    * Double Stacked Magnet
    * Die Cast Basket
    * Butyl Rubber Surround
    * Sensitivity: 87 dB @ 1w/1m
    * Frequency Response: 25Hz - 3kHz
Is this possible plain and simple...Readin ohn law as u read.
Posted By: Welsh
Date Posted: July 04, 2005 at 9:40 PM
https://www.the12volt.com/caraudio/woofer_configurations.asp
6ohm speak, stable for 1, 2 or 4ohm, stable amp.
I hope this is me.
Posted By: Welsh
Date Posted: July 04, 2005 at 10:02 PM
posted_image
Option 1 (parallel) = 3 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
posted_image
Option 2 (series) = 12 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
This would be correct, also doing this if anyone else wants to know
     1 DVC driver with Voice Coils in Series
Connecting the two voice coils of the driver in series (+ to -) will result in the following impedances:
Dual-6 Ohm Subwoofer: 12 Ohms
Dual-4 Ohm Subwoofer: 8 Ohms
Dual-2 Ohm Subwoofer: 4 Ohms
Posted By: stevdart
Date Posted: July 04, 2005 at 10:36 PM
What was the question?
Posted By: Welsh
Date Posted: July 04, 2005 at 11:43 PM
Is it possible for me to wire up a MTX 4250D Mono AMp to a 6 ohm 12" sub.
Based on these displays
Posted By: Welsh
Date Posted: July 05, 2005 at 4:37 AM
Anyone... im think 3ohm would be best bet.
