two amplifiers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59017
Printed Date: April 23, 2026 at 1:31 PM
Topic: two amplifiers
Posted By: choover567
Subject: two amplifiers
Date Posted: July 07, 2005 at 5:13 PM
anyone able to tell me how to install 2 amplifiers, have one. need to add another, not sure how the power and input works with two. also, im gonna be running two mtx 9500's and one 16-PRD1000.1 memphis amp for each one. 1000 watts to each one. goin in my 91 4 runner, think ima need another battery? thanks
Chris - 97 Toyota 4Runner
Alpine CDA-9884
Kicker SX1250.1
Kicker 15" L7
Posted By: stevdart
Date Posted: July 07, 2005 at 6:43 PM
9500 subs come in either single 4 ohm or dual 4 ohm (see https://www.mtxaudio.com/caraudio/products/subwoofers/thunder9500.cfm).  So..the best you can do is use the DVC 4 ohm and wire parallel to 2 ohms.  The Memphis amp will output into a 2 ohm load, which will be about 600 watts to each sub (see https://www.memphiscaraudio.com/products/details.asp?cat=&id=66&p=2).
If you want to get 1000 watts to each sub with the two amps, you will have to choose a sub that is available with a DVC 2 ohm voice coil configuration.
Date Posted: July 07, 2005 at 7:37 PM
since when did car audio get so confusing. =P
Alpine CDA-9884
Kicker SX1250.1
Kicker 15" L7
Posted By: stevdart
Date Posted: July 07, 2005 at 7:45 PM
Since the day when someone decided he wanted to run two thousand watts for subwoofers.  posted_image
Any time you make a change in your system you are opening a whole new can of worms.  The can you open with a doubling of power will be one that will take some time and effort (and $$$$) to get through.
...and your Memphis amps will have hookup instructions.
