wire questions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59282
Printed Date: May 13, 2026 at 3:59 PM
Topic: wire questions
Posted By: Jmeese
Subject: wire questions
Date Posted: July 12, 2005 at 10:56 AM
Ok got my component set today and looking at installing this evening.  I am assuming that I don't want to just wrap bare wire around the connection points on the crossovers.  I would probably want to crimp connectors on these right?  If so where can I buy these locally?  Best Buy, Home Depot?
Also what size spade connectors are needed for the speakers?  Are these standard?
Also what guage is standard speaker wire?  16?
Posted By: Poormanq45
Date Posted: July 12, 2005 at 11:00 AM
16awg wire should be fine.
For the spade connectors you can get them at your local home improvement store, or try walmart.
I don't know the exact size of your's as there isn't a standard. You can pick up a "kit" that contains like 20 of each size and contains ~10 different sizes for under $10
