Sealed Subwoofer Boxes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59410
Printed Date: May 15, 2026 at 9:05 AM
Topic: Sealed Subwoofer Boxes
Posted By: davis87
Subject: Sealed Subwoofer Boxes
Date Posted: July 14, 2005 at 9:55 AM
I trying to find out how much cubic feet does my box have? I need to know how to measure it. Both sides should be equal since it is a sealed box with a divider right?
Posted By: stevdart
Date Posted: July 14, 2005 at 10:35 AM
Use a flexible tape measure and reach through the empty speaker mounting hole to measure.  You want three measurements:  length, depth and height.  Do this for each chamber.
L x W (or D) x H = cubic inches.  There are 1728 cubic inches per cubic foot ( remember this number by multiplying 12 X 12 X 12 ).  So you will divide 1728 into the total cubic inches you arrived at.
example:  You measure 9.5 X 14 X 13.25 on the inside of the box.  Multiplied, the cubic inches is 1762.  1762 / 1728 = 1.02 cubic feet.
And yes, both chambers should be equal or very nearly so.
