Problems, 2 12" RF subs and Punch 300s amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59420
Printed Date: May 15, 2026 at 12:42 PM
Topic: Problems, 2 12" RF subs and Punch 300s amp
Posted By: jaurora
Subject: Problems, 2 12" RF subs and Punch 300s amp
Date Posted: July 14, 2005 at 12:11 PM
I have a 2002 ram 1500. I have a box with 2 12" RF punch (P1) subs. I am also using a RF Punch 300s amp. These subs are rated for 300 watts peak and 150 watts RMS. They are both 4 ohm SVC subs. I have the amp bridged and the subs are wired for a 2 ohm load. They sound like S**T. The amp lasts about 15minutes because it overheats and shuts down. The subs have that bottoming out sound as well (CLIPPING??). What is the problem? The amp is rated for 75x2 @ 4ohms or 150x2 at 2 ohms. I am unsure what it is bridged but I know when I use the 75x2 @ 4oms setup it sucks as well What is going on? Is the amp the wrong one or not powerfull enough? Are the subs just that bad? Is it wired wrong? I am a wiz with remote starters and alarms but I do not know the physics behind this stuff. This is why I look to yo guys for help.
Thanks...
MECP certified (If it really means anything)
Jeremy
Posted By: skoldspuppy
Date Posted: July 14, 2005 at 1:12 PM
Hi,
The first problem I see is you state you have the amp bridged and the subs wired for a 2 ohm load, well the 300s cannot support a bridge load of 2ohms, only 4 ohms or higher, thats the main reason its sounding like crap and overheating
So to fix this you need to wire your subs in series to get a 8 ohm load like the diagram below
posted_image
Now you can connect it to the bridged channel and then you need to properly set you gains, please take a look at this thread https://forum.sounddomain.com/ubb/ultimatebb.php?ubb=get_topic;f=2;t=030419 on how to properly set your gains.
After you do all this and it still sounds bad come back and well trouble shoot it some more
Later
--Skold
2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
Posted By: jaurora
Date Posted: July 14, 2005 at 1:26 PM
Thank you.
I forgot to mention I also tried it that way as well and it just doesent seem like that is the way 2 12" subs are suppoed to sound. It doese have that umph! Mabey because it is in the inside of a truck? Do yo think that the 300S is unshooting the subs?
Jeremy
Date Posted: July 14, 2005 at 1:50 PM
Well The P1's are rated at 150 RMS and the amp can only give them 75RMS at that 8 ohm load, it should still move them , but a better choice would be a Fosgate 301M which will watch the the RMS rating as it is a mono amp stable at 2 ohms
Another thing is your box, is it sealed or ported and how many cubic feet is it?
Rockford recommends 1.25 cubic feet for a sealed box and 1.75 cubic feet for a ported box tuned to 37Hz
if your box is to small it will really adversily effect the performance of the subs
Let us know
--Skold
4 Fosgate T152C
Posted By: jaurora
Date Posted: July 14, 2005 at 2:00 PM
Thats the reason!! I looked up the box specs. The box is a sealed box with duel chambers and each chamber is .57 cubic feet. That must be the problem. Hey I am open for options now. I guess I should of done my research first. Now I am out $180, no one to blame but myself. What would you reccomend?
Thanks.
Jeremy
Date Posted: July 14, 2005 at 2:19 PM
Getting a bigger box is what I would do first, one that has what Rockford recommends for air space per chamber, but since we are talking about a pickup truck it may be hard to build one or find one, I never owned a Pickup so I wouldnt know where to begin
Or option 2 is look for some subs that work in .57 cubic feet of air space and sell the fosgates
After that Im out of suggestions for now
4 Fosgate T152C
Posted By: jaurora
Date Posted: July 14, 2005 at 2:27 PM
Thank you for all of your help. I cant seem to find a 12" sub that would work in this limited ammount of space. Suggestions? This box is a custom fit box. As you know these pickup trucks are hard enough to put speakers in. I need to go with the different sub option first. Any reccomndations are helpfull.
Jeremy
Posted By: furflier
Date Posted: July 14, 2005 at 4:53 PM
Why not go with just one 12? You should be able to build a box to meet the specs.
Posted By: BoominRolla
Date Posted: July 14, 2005 at 5:06 PM
or 2-3 10"s... Never underestimate the power of a single sub set up or even 2 10's... i'm installing 4 8"s tommorow in a dodge diesel truck!!
