Speed Sensor wire for a 2005 Accord
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59480
Printed Date: May 16, 2026 at 7:30 AM
Topic: Speed Sensor wire for a 2005 Accord
Posted By: jkV6Accord
Subject: Speed Sensor wire for a 2005 Accord
Date Posted: July 15, 2005 at 8:38 AM
Im trying to install an aftermarker Pioneer Navigation system in my dash.  I read the previous post on the details of where the speed sensor wire is however when looking at the transmission block, I see a blue wire.  I just dont want to burn the computer if i attach the wrong wire.  Can someone please tell me the exact location. Thanks for your help.
Posted By: chungo
Date Posted: July 15, 2005 at 1:28 PM
Speed Sense blue/white    ECM/PCM
Notes: The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26. On the 6 cylinder models it is in the gray connector A, pin 11.
