Kicker Subwoofer Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59653
Printed Date: March 19, 2026 at 12:15 PM
Topic: Kicker Subwoofer Wiring
Posted By: BIglooney
Subject: Kicker Subwoofer Wiring
Date Posted: July 18, 2005 at 5:51 PM
Hey I was wantin yalls opinion on this. I've got 2 kicker cvr 12's ordered and there goin to be going in a sealed box. I've got a Memphis PR300.2 to push them for right now. There DVC and I was wonderin if it would be better to wire them in parallel and leave the amp in stereo mode to put 2 ohms into each channel,or to wire them in series for a 4 ohm load and bridge the amp over to mono. Tell me which one yall think I should do.
98' Nissan Frontier
2 Kicker Comp CVR's
Memphis PR300.2
Jensen 75.2
Pioneer 3-ways in tha doors
Factory tweeters
one crossfire tweeter for center channel
2005 Panasonic CQ-C5110U CD player.
Posted By: Blowntweeters
Date Posted: July 18, 2005 at 6:14 PM
that amp my handle a 1 ohm load if so great run it at 1 ohm if not go 4 ohms mono or 2 ohms you should get about the same power but with the 4 ohm mono your T.H.D level will be lower
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Date Posted: July 18, 2005 at 6:27 PM
i looked at all the specs for that amp  i would wire the subs in parellel  and then you can try it both ways to see how it sounds better to you
