Jensen VM9510 Installation
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=59691
Printed Date: March 20, 2026 at 5:11 AM
Topic: Jensen VM9510 Installation
Posted By: jabjib
Subject: Jensen VM9510 Installation
Date Posted: July 19, 2005 at 5:27 AM
I was wondering if anyone has ever used the Metra Radio Wiring Harness (VE-0180) for the Jensen VM9510.  I installed my own Piaa 525 drving lights but I have never installed an aftermarket radio/DVD player.  I just want to know if I can use this instead of splicing wires together.  Also I have a chevy Tahoe and from what I've heard  when you turn the car off the 7" Monitor flips shut, and hits the gear shift. Is there anyway to disable this.  I would also like to disable the parking brake feature too.  I know it is illegal but i'm going to do it anyway.  I've read that I can just ground the parking brake (Pink)wire and it will work fine.  What I basically want to do is to keep everything the way I have it now.  My radio doesn't turn off until I open the door. How do I keep this feature.  Thanks in advance for your help
Posted By: Velocity Motors
Date Posted: July 19, 2005 at 10:08 AM
I'm not sure this will work unless Audiovox makes Jensen car audio ( I"m not sure of this ). I would say just get the Metra harness for your vehicle and solder the ends to the Jensen harness.
