04 mazda 6 pac loc addition
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60188
Printed Date: April 23, 2026 at 4:14 PM
Topic: 04 mazda 6 pac loc addition
Posted By: No1stunna
Subject: 04 mazda 6 pac loc addition
Date Posted: July 27, 2005 at 10:09 AM
I was wondering if anyone knows if the signal going to the rear speakers is the same as the front... The rear speakers sound like they don't have as much bass and seem to be a filtered signal, and I didn't know if that is because of the speakers or the signal going to them. I only want to wire this once so I wanted to check first.        thanks alot
Posted By: Velocity Motors
Date Posted: July 27, 2005 at 10:01 PM
If the rear speaker's only have two speaker connections going to each, then it will have the same signal as the front. If there are 4 wires going to the speaker, then you have to find out which is the mid bas signal cause the tweeter signal will be crossed over.
Date Posted: July 28, 2005 at 4:09 AM
I forgot to add that it is a non bose, i didn't take the door panel off , so i don't know how many wires are going into the speakers, but at the pillar between the front and back the wires are: LR+violet, -pink    RR+WHITE/ blk, -blk/blue. hope that helps
