removal of back speaker pannel in 94 4run
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60399
Printed Date: April 01, 2026 at 4:32 AM
Topic: removal of back speaker pannel in 94 4run
Posted By: ryansams
Subject: removal of back speaker pannel in 94 4run
Date Posted: July 30, 2005 at 11:53 PM
how do i remove the back speaker pannel in a 1994 toyota 4runner top (the tweeters)&bottom (5 1/4) im a novice, any diagram sites would also be nice to have
Posted By: Hornshockey
Date Posted: July 31, 2005 at 1:50 AM
the top panel is just held in with clips; just pull gently but firmly around the outside of the panel and the clips will pop off.  7 or 8 of them all around the panel; pretty simple really.  Sorry I can't help you with those side panels though.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Posted By: ryansams
Date Posted: July 31, 2005 at 1:57 AM
in life when you are doing the best you can do ,........do better
