4 Channel Amp install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=60685
Printed Date: April 19, 2026 at 9:59 AM
Topic: 4 Channel Amp install
Posted By: h2opolo_1255
Subject: 4 Channel Amp install
Date Posted: August 04, 2005 at 3:22 PM
I'm going to be installing a 4 channel amp in my civic. when i bought the deck, (from a person not a store) they had it hooked up to a 4 channel amp. the way they had it set up had the speaker wires coming from the amp were running through the car to behind the deck and then it was spliced into the wiring harness in the back of the deck, so the signal ran through the factory speaker wiring. I'm wondering if there is any big advantages to doing this as opposed to just running new wire through the car directly to the speakers. also, if i do just run the wires to behind the deck, is there anything else i need to know?
thanks
andrew
Posted By: geepherder
Date Posted: August 04, 2005 at 8:43 PM
The biggest advantage would be time (much easier, less work). If you do this, just don't connect the wires from the radio to these as well. You can just imagine the number of people who will ask if they can use their radio and their amplifier to power their speakers and get more power.
------------- My ex once told me I have a perfect face for radio.
Date Posted: August 04, 2005 at 8:47 PM
cool. thanks a ton man.
