2001 Alero Wiring Diagram -
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6076
Printed Date: May 10, 2026 at 3:50 AM
Topic: 2001 Alero Wiring Diagram -
Posted By: aleroowner
Subject: 2001 Alero Wiring Diagram -
Date Posted: November 30, 2002 at 7:54 PM
The wiring diagram for the 2001 Alero (and probably Grand Am since they are basically the same car) posted in this forum does not match my vehicle - There is no switched power wire at the radio.
Could someone post the correct Pin Outs or tell me where to connect the "Ignition / Accessory " wire on an ALPINE RFU for a M-Bus changer.
Doug
Posted By: Velocity Motors
Date Posted: December 01, 2002 at 10:10 AM
You will need to grab the switched ignition wire at the fuse or at the ignition harness. The radio's DO NOT have a switched ignition wire anymore. It will probably be easiest to find a fuse that is switched with a DMM or light tester.
