| Print Page | Close Window |
spark plug-engine noisePrinted From: the12volt.comForum Name: Car Audio Forum Discription: Car Stereos, Amplifiers, Crossovers, Processors, Speakers, Subwoofers, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6089 Printed Date: May 09, 2026 at 11:04 PM Topic: spark plug-engine noise Posted By: djfearny2 Subject: spark plug-engine noise Date Posted: November 30, 2002 at 11:59 PM can some one tell me what are the best sparkplugs to get when haveing a multiple amp system in a car what is recomended by the top people this goes out to people like jeff i currently see bosch platinum plus 4 tip plugs in the car i am doing and no matter what i have engine noize can you give assistance and include if it is good to change plug wires as well. ------------- Jon Installer/Help Technician ---coral springs florida--- mecp certification is not always needed. I have it and it has not helped me out at all. my experience out shines it. Replies: Posted By: diabloed Date Posted: December 01, 2002 at 12:32 AM try using a resistor style plug
Posted By: Velocity Motors Date Posted: December 01, 2002 at 9:36 AM The plugs are only as good as the wires and if the wires are not thick enough, you loose in performance and in mileage. Chances are that you are not experiencing engine noise from the plugs or the plug wires. I had this same problem with a competition system that I put together for a customer a couple of years ago . They had some high end components ( 4 amplifiers and a plethora of speakers ) and had the capacitors and the full nine yards . After EQ'ing the system and then starting the vehicle, we had the worst noise from a system I had ever heard !! At first we took out the RCA's and temporarily hooke up another set from the shop and ran them into the EQ and same with the amplifiers...nothing ! Next of course we shortened our ground and made sure that we had absolute ground on the grounding plate we made and also beefed up the OEM ground to the radio, no good , the noise was still there. We isolated the power wires for the deck, isolated the RCA with copper piping under the dash against EMI and also went as far as replacing all the amps with a different manufacturer and no go. We finally went to test the battery and alternator at a friends shop and he noted that the battery was good, but the alternator was weak ( working at about 1/2 output power ). We got the customer to replace his alternator with a high power unit and problemo gone !! Here is anoise checklist that you can use for your system : Noise Elimination Checklist The following checklist can be used for the basic troubleshooting of noise in mobile audio installations. The key to success is to relax and systematically go through the vehicle. The problem WILL be found. Murphy’s Law states, however, it will be in the last place you look. 1. TO BEGIN: Be sure that system is correctly designed and matched for compatibility. 2. INSPECT VEHICLE: Verify ground from negative battery terminal to fender and/or chassis. Upgrade as needed. This connection must be capable of handling the current of the entire system. ASSUME NOTHING! 3. CHECK VEHICLE ELECTRICAL SYSTEM: Battery, alternator, etc. Make sure your alternator can adequately supply the sound system as well as other vehicle systems (alarm, lighting, etc.) AMPS/VOLTAGE NOT OK: See service technician to have system repaired or upgraded. 4. PROPERLY MOUNT COMPONENTS: 5. PROPERLY RUN ALL CABLES: 6. HOOK EVERYTHING UP: Follow the instructions provided with the component and be sure of polarity. Make sure everything is working and set all line levels. If noise exists, please continue... GENERAL PROCEDURE FOR LEVEL SETTING: When setting gain levels, always work from the source unit to the amplifiers. 7. IGNITION NOISE: Check for noise in each of the following switch positions: NOTE: Pulse Width Modulated headlight switches (like some Honds cars use) can cause a whining type of noise when on, verify this type of problem by turning lights on and off while listening for noise. If this is the problem, the headlight switch may need to be replaced with an alternate type. 8. GROUND LOOPS AND/OR RADIATED NOISE EXIST: Check resistance of all ground cables; consider using central point grounding. Resistance needs to be as low as possible (around .2 ohms) on your meters lowest scale. If not, re-do or upgrade cables. If it is not possible to get the resistance’s this low, try to get them all at an equal value (all the same resistance.) TIP: Use the combination of a DVM and a ground sniffer (plans available from our technical dept.) to find the best ground point. Remove the positive cable from the vehicles’ battery and check resistance’s from: 8.1 RADIATED NOISE: Place head unit next to amplifier and plug directly in (or use an isolated source such as a Discman or Walkman) and turn system on. Listen for noise. If noise is gone, please continue... Muting plugs can be used to systematically troubleshoot the point at which the noise is entering the system. Muting plugs consist of a male RCA end with the positive and negative (tip and shield) connected together (a dead short). Open RCA ends can become an antenna radiating noises into a sound system. By inserting muting plugs into the inputs of each component in your system one at a time the source of the noise can be found. This is a process of elimination starting with your amplifiers. Insert the muting plugs into the inputs of the amps. Turn on each amp (with the muting plugs inserted) one at a time and with the car running listen for noise. If none is heard, the amps are OK. If all amps are OK, connect the next piece in the signal path upstream of the amps (typically the crossover) by connecting its outputs to the amp inputs using normal RCA cords. Now insert the muting plugs into the inputs of that product and turn on the system. If noise is heard now, power the component with an external power supply. If the system is now quiet, the noise is probably entering through the components’ power supply. If no noise is heard, insert the next component upstream in the signal path and check it the same way. Keep working your way upstream all the way to the head unit. Once the problem is found, you can stop. 9. ANTENNA NOISE I: Unplug antenna from the back of the head unit and listen for noise. If noise is eliminated, see section 13. ANTENNA NOISE II. However, if noise remains: NOTE: The following checks will not be necessary in most cases, but if the previous checks are not effective, continue. 10. IGNITION NOISE II: Determine the source of the ignition noise. A. Check for loose or defective plug wire. 10.2 ALL CYLINDERS: Try the following fixes in order: 11. ACCESSORY NOISE: May be identified as a turn-on "pop", relay "pop", or other motor type noise. 12. ALTERNATOR WHINE: 13. ANTENNA NOISE II: Fixed mast or power antennas go to section 13.2... 14. You’re Done! ------------- Jeff Velocity Custom Home Theater Mobile Audio/Video Specialist Morden, Manitoba CANADA Posted By: jaxman Date Posted: February 27, 2003 at 7:25 AM Damn good guide :)
Posted By: Velocity Motors Date Posted: February 27, 2003 at 2:22 PM Thanks
![]() ------------- Jeff Velocity Custom Home Theater Mobile Audio/Video Specialist Morden, Manitoba CANADA Posted By: esmith69 Date Posted: February 27, 2003 at 6:45 PM yea that is one helluva good guide
Posted By: wvsquirrel Date Posted: February 27, 2003 at 9:25 PM Velocity is deffinately da man!
------------- Squirrel "No more Cpt. Kirk chit chat" If its too loud, then you're too old Donate to the12volt.com Posted By: ignitedchevy Date Posted: February 28, 2003 at 12:00 PM i had an engine noise problem in my 83 s10 ... i installed a scosche efx ground loop isolator and it fixed my problem ...
