2005 Durango
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61066
Printed Date: March 31, 2026 at 10:23 AM
Topic: 2005 Durango
Posted By: allencass
Subject: 2005 Durango
Date Posted: August 10, 2005 at 10:55 AM
I have a 2005 durango with the basic stereo system. I am adding an amplifier but would like to know if I will have to drill through the firewall or if there is a spot I can go through. Any help is greatly appreciated.
Allen
Date Posted: August 10, 2005 at 12:55 PM
Never mind, I went through the door jamb by the fender, that should do it, I'll post whether not I was successful, so if anybody else has a similar situation we'll know how to get past it.
Posted By: rallysport
Date Posted: August 10, 2005 at 1:30 PM
unless im reading this wrong you did it the ghetto way and ran it so when you open the door you see wire? bad.
Posted By: geepherder
Date Posted: August 11, 2005 at 8:30 AM
You can go through the fender well, above the lining, but I wouldn't run through the door jamb.  The wire can pinch and short out.  Check to see if there's a rubber plug in that vicinity that you can run through.  I've actually removed a fender on a couple of my cars just to get better access.  I wouldn't do this on a customer's car, of course, because of all the extra time it takes.
