2 mtx 12" 7500 series w/ bx1800d?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=61458
Printed Date: May 05, 2026 at 3:34 PM
Topic: 2 mtx 12" 7500 series w/ bx1800d?
Posted By: shortys015
Subject: 2 mtx 12" 7500 series w/ bx1800d?
Date Posted: August 16, 2005 at 7:18 PM
i have 2 mtx 12" 7500 series rated at 400watts rms ...i have a bx1800d because this amp is a monoblock amp i am wondering if i can still run these subs briged in series :oops:
P.S. my subs are dual 4 ohms voice coils
thanks in advance
Posted By: ghostridersol
Date Posted: August 16, 2005 at 7:32 PM
of course you can run both subs of the 1 amp as long as your amps ohm load ratings will allow it.
Date Posted: August 16, 2005 at 7:44 PM
so i am looking for the specs @..... 4ohm X 2 = watts rms ?????
Date Posted: August 16, 2005 at 7:48 PM
this stuff gets me sooo confused...sorry
Date Posted: August 16, 2005 at 7:54 PM
ok would it be easier if i just connected them like one sub for each connection on the amp like there are 2 +'s and 2 -'s on the amp so would it be better to put the 4 wires in the 4 spots or can i draw more power bridging them?
Date Posted: August 16, 2005 at 8:50 PM
If it is a mono block amp it is all 1 chan no mater how you hook them up
rockford wiring wizzard https://rockfordfosgate.com/rftech/wiringwizard.asp
