Which subwoffer is Better
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6161
Printed Date: April 22, 2026 at 9:42 AM
Topic: Which subwoffer is Better
Posted By: eeh1025
Subject: Which subwoffer is Better
Date Posted: December 02, 2002 at 8:52 PM
Hi there which sub woffer do you think is better Audiobahn AW1206Q, Alpine Type-R SWR-1241D or a JL audio 12 W6. thanks alot.
Posted By: bberman1
Date Posted: December 02, 2002 at 9:37 PM
Out of all the subs listed above the Audiobahn will move the most air. I have the AW1208Q’s and I can tell you that they hit and they sound clean too.  Are you looking for spl or sq?
Posted By: eeh1025
Date Posted: December 03, 2002 at 4:47 AM
Hey bberman1.  What is really the difference Between SPL and SQ I want Something that tumps really lound and sound good that can be heard coming a 1mile down the road.  Thanks alot for your help.
Posted By: AW1208Q
Date Posted: December 03, 2002 at 8:59 AM
SPL is strictly the louder the better. SQ is sound quality which is not nearly as loud as SPL but will sound alot better to the ear. The Audiobahn AW1206Q will thump alot harder than the other subs you listed. It is not the best sub for SQ but it can compete with some of the best out there. I would suggest the 08s over the 06s. They may cost alittle more but it is well worth the extra money. I am running 3 AW1208Qs pushed by 2 A18001DQ and they hit hard and you can hear me coming a mile down the road.posted_image
Posted By: bberman1
Date Posted: December 03, 2002 at 10:27 AM
What you looking for is SQ/SPL system, have to agree with AW1208Q I would go with the 08 over the 06 worth the extra money and it will hit very hard. But they are power hungry so be sure to get a amp that will put out enough juice, such as the Audiobahn A18001DQ
Posted By: eeh1025
Date Posted: December 03, 2002 at 11:51 AM
Thanks alot guys. One more question if i go with the 2 AW1208Q would i need just on Audiobahn A18001DQ or 2.  and i need 2, how would the Audiobahn A2300HCG 2-Ch Or the Audiobahn A2X600HQ. thank alot.
Posted By: bberman1
Date Posted: December 03, 2002 at 4:22 PM
It’s a good choice. I would suggest hooking up one A18001DQ for each one of your subs that’s a total of 2 amps. If you run that set up you will be amazed at what you have.
Posted By: AW1208Q
Date Posted: December 03, 2002 at 4:40 PM
the 08s need to be run in odd numbers. like 1 1208 or 3 or 5. this is due to they r dual 2ohm voice coals. if you just want 2 1208s get 2 A18001DQ and it will knock hard as hell.posted_image
Posted By: eeh1025
Date Posted: December 03, 2002 at 9:03 PM
Hey i just bought 2 A18001DQs and two Audiobahn 1208s.  i should get them in a few days.  I was wondering what is the best  box for these subs.  sealed, ported or bandpass, and what measurments should i go with.  thanks alot you guys.
Posted By: bberman1
Date Posted: December 04, 2002 at 12:50 PM
Personally I have tried both ported and sealed and I like the way that they sound sealed. They are designed to run ported but it will not harm them to run them in a sealed enclosure. If you go ported they need 3cu/ft per chamber and sealed 1 cu/ft per chamber here is a link to the box specs page for the subs. Off this page you can also get the port specs https://www.audiobahninc.com/tech/Audiobahn2002boxspecs.pdf You made a good choice and will be very happy once you get everything going. If you need any more help let me know and I will be glad to assist you.
