Satellite Antenna
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62379
Printed Date: May 06, 2026 at 1:47 PM
Topic: Satellite Antenna
Posted By: Walkercustoms
Subject: Satellite Antenna
Date Posted: September 08, 2005 at 7:00 AM
How do you mount the antenna for satellite radio?  How do you get the wire into the car?  Do you go through the weather striping?  I have never done one and its on its way and I just want to make sure I do it right.
Posted By: meh66
Date Posted: September 08, 2005 at 9:05 AM
The antenna for the satellite is magnetic and you need at least 2 square inches. Depending on the vehicle (Car or SUV). your install differs. I did about four so far. The first one was on a mercedes and I installed the antenna inside on the rear deck. The other car, I ran it under the rear window weather strip and through the trunk. The SUV was a different case, I notched out an area near the rear door to get the wire through. To be honest, I am not 100% satisfied with the SUV installs eventhough my friends are happy with them. I am currently inquiring about a glass mount  to use on vehicles like SUV or hatchbacks. Hope my little experience helps.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
Date Posted: September 08, 2005 at 9:44 AM
Great man thanks.
Date Posted: September 08, 2005 at 9:46 AM
If, I keep it inside will it still get good signal or will it be better to install it on the roof outside the car?
Posted By: Hornshockey
Date Posted: September 08, 2005 at 12:59 PM
It really depends on the area you live in; if you have good terrestrial repeater coverage; you will not have a problem keeping the antenna inside the vehicle.  If there's not good coverage in your area; you will have problems with losing signal from time to time.  I'm not sure if there's a source that can give you a coverage map or something for the repeaters; but I've just learned from trial and error that there is not very good coverage in my area.  I have since stopped putting antennas inside of vehicles.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
