Positive? Negative?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62490
Printed Date: May 07, 2026 at 9:46 PM
Topic: Positive? Negative?
Posted By: elliottruss
Subject: Positive? Negative?
Date Posted: September 10, 2005 at 2:11 PM
I am trying to install new front and rear speakers in my son's 91 Ford Escort GT.  How can I tell which wire is positive and whick is negative, or does it matter?
Russ
Posted By: tcss
Date Posted: September 10, 2005 at 2:24 PM
Yes it does matter. When you remove the stock speakers from the car the speaker plug should have a retaining clip on one side. The wire closest to the clip is the negative.
Posted By: dwarren
You won't hurt anything. If one you were to hook one speaker up out of phase it would sound bad. Trial and error here I guess.
Posted By: redpeppers
Date Posted: September 11, 2005 at 2:28 AM
what i do is take a batt. and cut the factory harness and pop the spker.  if it goes out u have the positive wire.
Where theres is a wire there's a way.
Posted By: Francious70
Date Posted: September 12, 2005 at 10:32 AM
