Tweeters pop w/sat radio ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62548
Printed Date: May 09, 2026 at 12:28 AM
Topic: Tweeters pop w/sat radio ?
Posted By: Fastlearner
Subject: Tweeters pop w/sat radio ?
Date Posted: September 11, 2005 at 9:47 PM
Installed a sirius starmate into a 2003 Nissan Maxima/ hardwired fm modulator. After the instalation the tweeters will pop only on the xm radio. Tried switching out the fm modulator and still had the same resault. Tomarrow i'm going to try to install a different unit and see what happens, also going to try to do bass blockers on the tweeters and see if that helps. If anyone has had this problem before, any help will do.
Posted By: dwarren
Date Posted: September 11, 2005 at 10:15 PM
To me that just sounds like fm interference. And if this is the case bass blockers aren't going to do much.
Posted By: oxygen65
Date Posted: September 12, 2005 at 2:48 PM
usually tweeters pop when you put to much power into them, but i agree with dwarren bass blockers are not going to do anything for that, i would go with getting a new unit to see if that was the problem
Date Posted: September 12, 2005 at 4:39 PM
Just tried the bass blockers and got nothing. Another installer said he had the same problem in a newer accord. He tried everything. Could it be that Tweeters get to much power from the sat radio. But it wouldn't make sense that it would work fine with cd and other radio stations.
Posted By: oxygen65
Date Posted: September 13, 2005 at 5:19 PM
yea i dont see why they would pop unless there is a noticible difrence between the cd play and the xm radio, i would just say that you should just go get another unit and see if it does the same thing.
