dead battery after installing system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62659
Printed Date: May 15, 2026 at 10:38 AM
Topic: dead battery after installing system
Posted By: qmw54
Subject: dead battery after installing system
Date Posted: September 13, 2005 at 9:45 PM
ok i just put a amp and 2 subs in my truck factory radio .... and had power untill i tryed to start it and then ever thing went dead .... light dont work .... nothing ...... but i can jump it off and it will start and run but as soon as i shut the engin off every thing dies the next time i try to start it ......... i need help quick!!!! thanks qmw54
Posted By: stevdart
Date Posted: September 13, 2005 at 10:17 PM
Take the battery out and get it tested.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Posted By: Poormanq45
Date Posted: September 13, 2005 at 10:28 PM
ouch, you just killed your battery
Probably drained it too low
Posted By: qmw54
Date Posted: September 13, 2005 at 11:48 PM
is there any thing else that it could be ??? like security ??? thanks qmw54
Posted By: sedate
Date Posted: September 13, 2005 at 11:53 PM
Hmm..
Your first think to check is your battery. After that is elminated, post back and we'll play the guessing game eh?
------------- "I'm finished!" - Daniel Plainview
Posted By: parrot
Date Posted: September 15, 2005 at 3:18 AM
I would make sure the amp isn't staying on. Is the remote power wire on the amp hooked up to a key on position somewhere in your system? Amp might have killed your battery and sometimes they don't like to come back from the dead, especially if the battery is a few years old.
Posted By: Alpine Guy
Date Posted: September 15, 2005 at 11:57 AM
Chances are you battery was at the end of its life, and during the install when you had the doors open and the dome lights on they drained your battery too beyond its life and now you have a dead cell. It would have happened sooner or later with the stereo. Orrrr.... if your battery is fine theres a problem with the alternator, or wires/connections in between ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: qmw54
Date Posted: September 16, 2005 at 8:20 PM
it was the batt... thanks fir the help
Posted By: oxygen65
Date Posted: September 17, 2005 at 6:01 PM
it is most likley your batter from draining it to low and there is no way to bring that back you jsut have to go get a new one, but as long as u are gettin a new batter why not get one that is used in car audio, go get urself an optima yellow top if you need a new battery, it might cost a little more but i like them.
Posted By: oxygen65
chances are that it is the battery, so if you get a new one, go with the optima yellow top, they cost a little more but i think it is worth it
