annoying pop when amp shuts off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=62750
Printed Date: May 14, 2026 at 2:10 AM
Topic: annoying pop when amp shuts off
Posted By: epridaz
Subject: annoying pop when amp shuts off
Date Posted: September 16, 2005 at 12:21 PM
Hey, whenever my amp shuts off I hear that pop noise come from my speakers. What can I do to fix this? Could it be that I am using one remote wire to turn two amps on and off? Also it only makes the noise through my 4 channel amp.
Posted By: DYohn
Date Posted: September 16, 2005 at 1:11 PM
This is actually normal, especially when using lower-end amps.  What you need is an off-delay circuit (or "turn-off pop eliminator") like one of these.
Posted By: Cougar.Modder
Date Posted: September 16, 2005 at 2:24 PM
I had this same thing happening to me as well and it turned out just that the gains on the amps or in my case my Line driver were set to high. Turned them down and POP was gone. Try that first and see if it helps out.
Alpine 7830 HU-4X100 W McIntosh -2X110 W McIntosh-MB Quart Q's Mid Tweets-4X10" Phoenix Gold Subs-Phoenix Gold EQ215ix-AC Epi-PG Line Driver-Phoenix Gold 1 Farad Cap -Clifford Avantguard 4-2 Ear Plugs
Posted By: TruckSystem
Date Posted: September 16, 2005 at 3:52 PM
My old cheap amps were doing that, upgrading them to something halfway decent removed the problem. I wish it would have fixed my engine noise on the passanger side too, but still working on that.
2003 Chevrolet Silverado Standard Cab ~ Alpine CDA-9851
Diamond Audio D3600.1 ~ 2x Diamond Audio TM310D4
Diamond Audio D3400.4 ~ Diamond Audio Hex S600s
AstroStart RS5204 Remote Start/Alarm
