Thin mount mid
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63111
Printed Date: May 09, 2026 at 2:30 PM
Topic: Thin mount mid
Posted By: dday
Subject: Thin mount mid
Date Posted: September 22, 2005 at 9:18 PM
I'm thinking about adding a stand alone mid bass driver to the front doors of my 02 Chevy Avalanche. Currently installed in the factory location I have the new Alpine type R 6.5 seperates, I believe if I can find a thin mount 6 or MAYBE an 8 I would have room to have all 3 speakers without to much fabrication. I have looked but everything I find is discontinued ie JL IB4 and I found 1 Kicker can't find the model at this time. Does any quality name brand make a good sounding thiner mid? Thanks in advance.
Posted By: stevdart
Date Posted: September 23, 2005 at 8:03 PM
Do you have any room to modify with a MDF baffle (distance to the grille)...in effect positioning the speaker more forward so that you don't have to have so much depth...and with this in mind, what is the maximum depth you are looking for?
Posted By: dday
Date Posted: September 24, 2005 at 8:03 AM
I haven't pulled exact measurements yet but from an eye, with a baffle between the panel and the grill I gain about 2-3in which I believe I can put a normal 6 like a JL and MAYBE some more standard size 8's. If I can't find a thinner speaker I'll get more serious with measurements, I know if I find something that in 3in or thinner I'm good.
Posted By: sedate
Date Posted: September 24, 2005 at 9:37 AM
Huh?
Lotsa 6.5's that are thinner than 3".... generally something on the order of 2.5 - 2.7" -ish .....
With a baffle (how I did my entire car) I betcha any given 6.5 would work great.
Posted By: sedate
Date Posted: September 24, 2005 at 9:40 AM
Oh yea... u want to *add* a second pair of 6.5's?
Hmm.. running the same frequencies you'll have some nasty cancellation like that.
How were you going to run those? You understand you cannot simply run them off the mid+- on the Alpine xovers right?
