2 Brutus amps?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63162
Printed Date: May 09, 2026 at 12:11 AM
Topic: 2 Brutus amps?
Posted By: southernshock
Subject: 2 Brutus amps?
Date Posted: September 23, 2005 at 5:50 PM
Alright guys i have 2 13.5 Jl W7 subs and want to push them to hit to there potential......... well ive got 2 Hifonics Brutus 1500 watt 1 channel amps and im needing a lil help clearin some stuff up is a 1 channel the same as a mono because ive heard they are diff and i dotn see why they would be if they are explain please lol and if i do go with both of these im going to run both of them to the same battery and ive heard thats not a good idea???? what should i do to make these 2 amps the BEST possible? thanks guys
Take It Easy ~ Cullen
Posted By: DYohn
Date Posted: September 23, 2005 at 6:26 PM
Sentences.  They make understanding what the heck you are trying to ask much easier.  Learn to use them.
Date Posted: September 23, 2005 at 6:30 PM
i reckon yall aint from texas haha sry bout taht all i wanna know is how i should wire 2 1500 watt hifonics 1 channel amps to 2 13.5 W7's and were i should hook them up for power
Posted By: supradude
Date Posted: September 23, 2005 at 7:39 PM
You might need to upgrade your alternator. As far as hooking to the same battery, why not? You shouldn't need but one battery with those amps.
'85 Toy
Posted By: uthinkuknoaudio
Date Posted: September 23, 2005 at 8:22 PM
I reckon you need to upgrade your English haha... sentences are crucial... Anyways, you might need an alt upgrade or multiple batteries. Run 1 amp per sub, and wire your subs to the 1.5 ohm load (DVC3). You'll get plenty of power.
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
Posted By: tcss
Date Posted: September 23, 2005 at 8:27 PM
If you run one amp per sub you could NOT get a 1.5 ohm load. JL 13.5" W7s have dual 1.5 ohm coils so you would either get a 3 ohm load or a .75 ohm load. I'm really getting tired of correcting you. "U"
Posted By: gcorrea
Date Posted: September 24, 2005 at 1:15 AM
hey, whats up with that,  im from el paso tx dont give us a bad grammar image.lol.
gcorrea
Posted By: DYohn
Date Posted: September 24, 2005 at 12:08 PM
Connect each 13W7 as a 3-ohm load (VCs in series) to each Brutus.  It'll produce around 750 watts RMS into that load.  It'll be fine.  Trust me.  posted_image
