Door speaker problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63172
Printed Date: May 09, 2026 at 6:08 AM
Topic: Door speaker problem
Posted By: f150on22s
Subject: Door speaker problem
Date Posted: September 23, 2005 at 8:12 PM
I am installing Audiobahn door speakers in my 2001 F-150.  The front door speakers went in fine, but I'm having a problem in the rear.
These speakers have 3 leads on them, and I assume that I have them wired properly because I have tried different connections with these.  So right now I have two leads hooked up and they sound fine.  But once I mount them back into the hole it turns off, as well as all of the other door speakers.  If I tap the speaker a couple times it will start playing, but once I turn my truck off/on it stops again.  Whats the deal?
Posted By: sneakycyber
Date Posted: September 23, 2005 at 8:25 PM
what kind of vehicle? year make model
Date Posted: September 23, 2005 at 8:30 PM
2001 Ford F-150 single cab
Posted By: sedate
Date Posted: September 24, 2005 at 1:22 AM
wait wait wait wait wait wait.....
You're driving a F150 on 22's (!!!) and you're installing Audiobahn speakers?
Huh?
To quote our admin:
"gaaaaaaaaaaa....."
Date Posted: September 24, 2005 at 11:06 AM
Check to make sure the speaker terminal is not grounding out on the chassis of the speaker. or on the door frame.
Posted By: wranglercory
Date Posted: September 24, 2005 at 6:19 PM
try one speak at a time to see if you have a bad spkr
