03’ is300 stereo wire color befor amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63713
Printed Date: May 08, 2026 at 9:17 AM
Topic: 03’ is300 stereo wire color befor amp
Posted By: piggypigs3000
Subject: 03’ is300 stereo wire color befor amp
Date Posted: October 03, 2005 at 12:19 PM
I wanted to do a after market deck with a psi2 insted of bypassing the factory amp, and wanted to know if any body could help me out with wiring up the psi2 on the amp side?
Posted By: raydawg357
Date Posted: October 04, 2005 at 2:01 PM
The factory amp is located high in passenger kick panel.  you can trace the wires there.  Plug into the amp are normal toyota plugs.
Do it right the first time
