50 Hz seems low for 6.5 & 6x9
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=63960
Printed Date: April 18, 2026 at 7:40 AM
Topic: 50 Hz seems low for 6.5 & 6x9
Posted By: johnlarkin
Subject: 50 Hz seems low for 6.5 & 6x9
Date Posted: October 06, 2005 at 9:53 PM
That is the low frequency range of my two pair of new coaxial speakers.  Seems low when I read about subwoofers going to 150Hz.  I hate to doubt manufacturer specs but right now I do.  Just wanting to ensure as much life as possible for speakers and amps.  Comments?
Posted By: dwarren
Date Posted: October 06, 2005 at 9:57 PM
They can play that low, but not particularly successful. Try crossing them over at 80hz.
Where do you have your subs x-over?
Date Posted: October 06, 2005 at 10:18 PM
No where yet, I am starting from scratch.  It will be a JL 8" 8W0-4 that is on the way to me.  I plan to power it with a 90 watt bridged Sony amp in mono that I have had lying around for a long time.  The specs say to use a 1st order passive crossover (inductor only).  It lists specs for the coil: 6.2mH for 100Hz, 4.2mH for 150Hz.  Is a subwoofer that sensitive to dead spots in the crossover or am I just wanting to limit it since that is where it operates best?
Secondly and most unpopular, I have some 4" coaxials in the dash, mainly to act as tweeters.  Their low range is 90Hz.  I guess I should cross those over higher too.  Recommendation other than discarding them?  Hehe
Posted By: dwarren
Date Posted: October 06, 2005 at 10:30 PM
There is no "right" way to set crossovers, rather tune it to where it sounds best. Usually people start off with a high pass filter set at 80hz  for the interior and the sub with a low pass filter around 80hz. Again diffierent systems require different x-over points, so experiment.
Paper weights for those 4"s
